KubeDesign plasma stands
Discussion in 'Plasma TVs' started by klnc, Mar 3, 2003.
  1. klnc
    klnc
    Oct 2, 2002
    359
    London
    +21
    Does anyone own one of these?? I haven't got a suitable wall to hang one on and the bird has issues with the amount of AV equipment on show, so this looked perfect. For those that haven't seen one, they are self contained stands where the screen is lowered into the stand when not in use....
    http://www.kubedesign.co.uk/kubic_kd3p.htm
    Anyway, I am interested if anyone has one re build quality, reliability etc... Also, interested if you can get them custom built to increase the amount of space available for the centre speaker.
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    If they're anything like the Longbow furniture (which also has a version with center speaker shelf and acoustic doors - or custom designs) then I would heartily recomend it.
    A recent customer of ours has a wheeled version under a cupboard in the lounge - in the cupboard sits the equiment all attached to a Panny tuner box, then the tuner cable, power lead and center speaker cable all run to the cabinet which can be wheeled out to the viewing position when required and totally hidden when not needed.
    The whole thing uses RF recievers built into the movable cabinet so that you don't have to look at any of the equipment, and signals are sent down a fourth cable into an RF sender in the cupboard with the rest of the stuff (the Panny tuner of course using the RF reciever on the plasma).
    Shame I haven't got any pictures....
