You’re not going to get a massive upgrade unless you get an oled. The KS still holds its own today.
Are you thinking of the 9500? The lower KS-series models like the 9000 were edge-lit local dimming systems.
I have been looking at the Panasonic gz950 would you say say this is a good upgrade in terms of picture quality etc to my 3 year old ks9000
Do you know if the cantelever wall mount I have on my samsung will fit the PanasonicYes. Definitely. Infinite contrast ratio.
Thanks the pana is 400 x 300 mine is 400 x 400 but it has multiple holes to adjust on the wall bracketsDo you know if the cantelever wall mount I have on my samsung will fit the Panasonic
