Question KS7000 and UB700 HDR Dull Colors Issue
XstreamToxics
Ive got an issue with HDR playback.
I have the Mad Max UHD disc and when I play it there is an information windows that says 4K HDR and some other information. But the problem is that the colors are dull and look a little washed out. I can correct this issue if I pull out the HDMI cable from the One Connect Box whilst the disc is playing and then plug it in again.
Doing that makes a tremendous difference because it will make the colors very vibrant and everything will just start looking very good instead of washed out.
So why is it doing this? Is it the TV or the Bluray player? Its starting too get annoying too pull out the HDMI cable everytime I want too watch a movie.
I appreciate any help I can get with this issue
two2midnight
What is the other information specifically that on the third line for the HDMI output on the UB700? Sounds like you might be getting SDR BT.709 rather than HDR BT.2020.
Might be a player and/or TV settings issue.
PS hot plugging HDMI cables is usually not recommended.
XstreamToxics
This is the Playback Info
XstreamToxics
How I like it:
How I don't like it:
There really is a lack of color in the second picture. I don't know if you can see that with these pictures because I made them with my phone, but the difference is huge.
MrOpinionated
You need to make sure that HDMI UHD Color is enabled as otherwise the port is running at 1.4 rather than 2.0 and will not pass through the extra HDR info properly, if you had a Sammy Blu-Ray player it would have probably auto recognised it and changed it, but we all know competing brands don't always necessarily play nice together. Also it might be worth checking that the HDMI cable you are using is Premium Certified as a general High Speed one may not be up to the job properly, especially if you are sending through all that lovely HDR 4K goodness.
XstreamToxics
HDMI UHD Color is enabled and I have a High Speed HDMI 18Gbp/s Supporting Deep Color and HDR.
The problem is that if I start a movie with HDMI UHD Color On it will still look bad and the only way too fix it is too pull out the HDMI cable and then put it in again or by turning off HDMI UHD Color and then turning it on again.
two2midnight
Perhaps try using a different HDMI port on the TV
MrOpinionated
Ok, so somehow the TV is not receiving the right metadata information from the Blu Ray player, until you give it a kick.... May I ask what options you have for color output from the Blu-Ray Player? Especially anything to do with Deep color or 4:4:4?
two2midnight
Also try setting UB700 to output 10bit 4:2:2.
XstreamToxics
I have deep color on Auto (12 bit) and Colour mode on YCbCr (Automatic)
Abacus
If using another input doesn’t work, (And you are using the main HDMI out on the player) make sure the player is turned off before selecting the Blu-ray input, thus making sure that the player is always turned on last. (Also check to make sure both the TV and player have the latest firmware updates)
Hope this helps
Bill
XstreamToxics
Hope this helps
Bill
It did not help :(
The weird thing is that I just put in The Martian UHD disc and the HDR started without a problem. So is it the disc that is bad or is it the 4K player that doesn't read the discs properly.
Should I return the Panasonic UB700 and go for a Sony X800 instead?
paulr2006
It did not help :(
The 700 is an excellent player & lots use it with various TV manufacturers without issue & whilst it could be faulty I would suspect the TV having an issue. Do you have a friend with a 4K set you can try it on?
XstreamToxics
No I don't know anyone that has a 4K TV. The thing is that HDR works on Youtube in the build in TV app, and it works from what I've seen on The Martian but not on Mad Max. Because on Mad Max the color is very "sandy" and not vivid, but if I turn UHD Color Mode off and then on again it will have that pop effect with colors and the colors are then very beautiful. So could it be a problem with the Mad Max disc?
mbmapit
It did not help :(
This IMHO all points towards an EDID/handshake issue. The TV is not seeing the correct signal or the player is not sending the correct signal. HDMI can be a real PITA at times. Have you tried a different cable just in case? Are firmwares up to date on all components? If you switch to the correct input on the TV and turn the player on from a completely off state what happens?
paulr2006
I guess it could be a faulty disc but don't think I have seen it mentioned anywhere?
XstreamToxics
I have 3 HDMI Cables but they are all the same brand and model, but I will try changing HDMI and report back.
mbmapit
Sorry I must have missed your above post. It is only on a certain disc? Are you 100% sure? What I mean is, have you carried out exactly the same tests with both discs e.g. switching to correct input and then turning on the player and putting in the disc and then turn all off and start again but inserting the different disc?
TellyTel
How long you had the UB700, maybe try to get a replacement, or try getting a replacement one connect box, maybe start with a different HDMI cable first.
XstreamToxics
Something weird happend this time when I started Mad Max. First it started playing without the HDR and then after a few seconds of non HDR their was some weird distortion and then it popped into HDR. This has never happend before I've always needed too turn UHD off and on again but this time it did it automatically (with distortion)
