Krell 300 CD player
Discussion in 'Hi-Fi Stereo Systems & Separates' started by maidened, Sep 14, 2007.
  1. maidened
    maidened
    Hello everyone. I have just bought this player from a friend. The unit has had a new laser fitted and works perfectly.The Krell is seven years old with little use and he only had the laser changed as a matter of course. How much life do you think will be left in this player?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    With a new laser,you should see several years of use,and the player itself is a very robust and high quality device.
    I'd not have any worries myself.
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    7 years is young, my CD only spinner is a Sony ES unit dating back 12+ years and with no transports or laser assemblies left. A quality unit like a Krell should be supported with the availability of servicing and spares for a while longer than 7 years, especially when spending that sort of cash (rrp). I think your investment is safe.
