kp44px2 problem?
Discussion in 'General TV Discussions Forum' started by mickey, May 25, 2003.
  1. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    hi just a quickie about a blue ghosting problem on my tv , i cannot remove it even if i turn off the blue drive and cut off in the service menu , is this a serious problem? or maybe something that can be cured by other means rather that electrical setup, looks to me like the blue is maybe not really in focus like when something goes all fuzzy when out of focus then turns into a nice sharp image when brought into focus(grasping at straws?) . any opinions appreciated. there are some pics here www.hanv.freeserve.co.uk to show you what i mean about the ghosting. cheers for any advice.
  2. nathan_silly
    nathan_silly
    Is it across the whole of the screen?
    If so the blue focus pot needs adjusting..
    You don't want to adjust the CUT & DRV settings- put them back! (I hope you've wrote down the original values)
    My Tosh RP looks like that (but much much less so) on the far left.
    Oh it could be also the blue lens requires re-focussing, however the blue focus pot (usually behind the speaker grille) is the most easiest to get access to.
    Bring up the blue convergence grid, and adjust the blue focus pot until it's the sharpest. You'll need to reconverge your screen for each aspect mode & display type (PAL & NTSC) what fun! :D
    If that's not enough then the blue lens needs adjusting as well.
    Read here for more info...
    http://www.avforums.com/forums/showthread.php?s=&threadid=81122&highlight=focus
  3. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    396
    22
    Gravesend/Kent
    +16
    i AGREE WITH PREVIOS EPOSTER, IT IS DEFFINATLY A CONVERGANCE PROBLEM,
    i did have the SOny Kp41ds1u, and any slight klnock on the tv would knock the convergance out, and i would have to bring up the cross and converge all colours again,
    the trouble with having kids!
