KP44PS Grainy
Discussion in 'TVs' started by llcooljazz, Apr 4, 2003.
  1. llcooljazz
    llcooljazz
    Just got this TV today and generally its sublime. But via the RGB scart it does become pixelated sometimes, espeically notcable on Sky channel "Trouble". Even though it was apparent on some Sky One programmes, i was just wondering if its my setup thats wrong, and should i go to the service menu to sort it. Or maybe my scar lead is poo. Help is very much appreciated.
  2. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    Graininess on digital? Dont you mean blockiness or pixellation. On a 44" TV I imagine you will see alot of digital pixellation and blocks due to rubbish bit rates of the digital channels.
  3. llcooljazz
    llcooljazz
    oops i meant plixellation, my bad, any ideas how i can reduces its effect?
  4. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    -Make the picture softer.
    -Sit further back
    -Buy a smaller TV ;)
    Unfortunately there isn't much that can be done.
  5. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    RPTVs are going to highlight the limitations of regular aerial and satellite broadcasts, and you'll notice much more how the weather affects this (especially with the prolonged dry spell recently). A component or RGB DVD feed will still knock your socks of. Occupational hazard of RPTVs I'm afriad, but well worth it when it comes to playing shiny discs.
  6. llcooljazz
    llcooljazz
    Thanks guys, to be honest it wasnt that bad, i was just wondering if it could be imporved, but I'm still very happy, thanks again for help
  7. scooby do
    scooby do
    Dec 11, 2002
    1,769
    48
    +37
    I too have a KP44 PS2, make sure you have set the TV up correctly. You really require a disk like AVIA. Depending on where you are in the country I may be able to help. Brightness contrast and sharpness needs to be adjusted and also SVM needs to be switched off IMHO. I have SKY digital with max signal strength and almost max quality and Shrek last night was as good as DVD!!!!!!!!!!!! Even the low bitrate channels look reasonable. Compared to my old Philips Pixelplus this TV handles all signal sources so much better. LL do you also have a sound system for your TV as I might be able to help there as well!!
    Regards
  8. llcooljazz
    llcooljazz
    Cheers Scooby for help but I'm happy with TV pic.
    Though without sounding like an idiot whats AVIA and SVM?
  9. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    AVIA disc allows you to set up the picture geometry using the enginners menu isnt it?
