Quantcast
koreandvds.com site down last two days?
F
FoxyMulder
Just you i suspect as i can get in, perhaps you need to change your settings in the control panel and internet options are your security and privacy settings too high ?
Have you got a firewall blocking you from gaining access to the site ?
You can also configure your timeout settings and i would recommend trying some other sites just to make sure everything is ok.
Lex
Thanks Foxy. Very strange. I am not having any problems anywhere else, nor do I have my security settings high :confused:
I am getting the gateway timeout message instantly which I thought was strange... I'll go delete some cookies and see what happens...
A
APPRIA40WR
Their site's always be rubbish and full of minor problems.
Fine here on NTL but if I try and open up another window on their site, it packs in.
F
FoxyMulder
I was just reading the Korean.com forum boards and they seem to be having major problems, lots of disgruntled customers and people seem to be cancelling orders and that seems unusual for that site, i can't use them anymore as they now no longer take American Express :(
Similar threads
