Kood filters
Discussion in 'Photography Forums' started by Biscuit761, Sep 19, 2007.
  1. Biscuit761
    Biscuit761
    Feb 1, 2006
    3,310
    +507
    Anyone use "Kood" filters, look a good price on 7 day shop, thinking of buying a few, possibly dark grey graduated, a tobbaco graduated, 85A and a ND4.
    Reports would be great.
    Bill
  2. rizingstar
    rizingstar
    Aug 28, 2007
    1,015
    Newcastle Upon Tyne
    +187
    I was looking at those aswell Bill,I've just had a search on deviantart.com and typed in kood for a search,a couple looked good,maybe try Flickr aswell and see what it brings up?
    edit:just searched on Flickr and there a some great kood filter shots.
  3. horribleman
    horribleman
    Jan 28, 2005
    527
    28
    +47
    I have a couple, they are fine. They don't come in a plastic box like Cokin, instead a plastic sleeve thing, but the filters themselves seem fine.
  4. Fozzybear
    Fozzybear
    Dec 10, 2005
    1,871
    83
    +295
    Yup, what he said. :)
  5. Biscuit761
    Biscuit761
    Feb 1, 2006
    3,310
    +507
    Having a look on Flickr, your right about the quality of the images, superb, one or two questions
    If you are using a graduated ND and you want to shoot say 2/3rd sky and 1/3rd ground or vice versa how do you do it when the grad runs out at the middle ?
    Also saw a lot of Infra Red shots on Flikr, is that just using an IR filter or do you need special lenses / camera ?
    Bill
  6. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    Biscuit761 - cokin 'P' (and therefore kood) filters are rectangular .
    The holder rotates and you can adjust the filter in the holder to adjust where the grad comes in, to a good extent.
