Quantcast
Kobo has reset itself twice now
SugarSpike
I got a Kobo for xmas, I set it all up. A few hours later when I turned it on it said restoring and I couldnt do anything with it for a few minutes, when it came back on it was at the setup screen again.
So I reset it all back up and it was working fine for the next few days, then I turned it off mid book and more or less turned it straight back on again to see if it would return to my page, but again the setup screen came up, which I skipped, my downloaded books seemed to be on there but my settings had reset and the bookmarks also.
Im wondering if this is a common thing that maybe a update might fix, or should I think about exchanging it?
