Knowledge Maketh man
Discussion in 'Past Entries' started by spear321, Feb 20, 2013.
  1. spear321
    spear321
    Mar 16, 2006
    117
    Manchester UK
    +36
  2. shotokan101
    shotokan101
    Jun 16, 2009
    75,598
    26
    Glasgow
    +25,589
    Hope you don't mind Paul :)
    I do like alternative theme interpretations - and I like the concept here :)
    Find it interesting trying to picture you with your headphones on in the scrum trying to grab [-]a shot of[/-] the Tight End :D
  3. spear321
    spear321
    Mar 16, 2006
    117
    Manchester UK
    +36
    Thank you I could not work out how to get the photo in...
  4. shotokan101
    shotokan101
    Jun 16, 2009
    75,598
    26
    Glasgow
    +25,589
    You're welcome - you just go to the picture in Flickr and select the "Share" option and from the drop down just make sure that "BBcode" is selected and use the size dropdown to select the image size to link to - then copy/paste the text in the box into your forum post :)
  5. spear321
    spear321
    Mar 16, 2006
    117
    Manchester UK
    +36
    Tight end is american football it would be the Hooker:)
    Still sounds complicated, will try to get it right next month
  6. shotokan101
    shotokan101
    Jun 16, 2009
    75,598
    26
    Glasgow
    +25,589
    ...much more enjoyable grabbing a Hooker I guess ;)
    It's not complicated - despite how it sounds - dive over to flickr and look - it's really just about 3 or 4 clicks and you're done :thumbsup:
