Klipsch Subwoofer through Marantz SR7007
Discussion in 'AV Receivers & Amplifiers' started by stevenc1970, Jul 14, 2015.
Tags:
  1. stevenc1970
    stevenc1970
    Dec 27, 2010
    7
    3
    The only way I can hook this sub up is through the LFE jack. With this said, can someone recommend what I should dial the settings to on the back of the subwoofer? Thanks!!
  2. dante01
    dante01
    Mar 5, 2009
    46,552
    +11,216
    Set the sub's frequency dial as high at it allows. Set the volume on the sub to about one third and set phase to 0°.
    Once ths is done you can run the receiver's auto calibration.
  3. stevenc1970
    stevenc1970
    Dec 27, 2010
    7
    3
    this was exactly what I needed. Thanks!
