I am building my first home theater, I bought all Klipsch speakers, and SVS subs.
My bookshelves are the Klipsch R41-M speakers with binding posts.
My receiver is the Denon X3700H
The banana plugs I want to use are the Sewell Silverback plugs both right angled for the speakers and straight for the receiver.
When I pull the dust covers out the hole that remains to plug into looks very small to me.
IT is larger than 1/8 jack for headphones, earbuds, external speakers to pc etc...
I was going to order the Sewell Silverback banana plugs, they check all the boxes for me, BUT I am concerned that they will actually plug in and fit properly.
The specs are:
Does anyone have Klipsch speakers like these and banana plugs installed that can confirm they will plug in?
Sewell says they should but check with Klipsch, Klipsch says the exact opposite, they should but check with Sewell, LOL.
I also have the center speaker and 2 floor standing speakers as well, they all have the exact same binding posts as the surrounds, and I am assuming the Denon X3700H receiver does as well.
I would just like to hear a confirmation from someone who actually has installed them.
these are the speakers: Speakers, Headphones, and Premium Home Audio | Klipsch
These are the plugs: Silverback Banana Plugs with Right Angle Connectors12 Pairs
This is the receiver: AVR-X3700H (2020 Model) 9.2ch 8K AV Receiver with 3D Audio, Voice Control and HEOS® Built-in AV Receivers | Denon
Any help confirming that these will be compatible would be great, thanks for reading.
The specs are:
- Total Length: 1 3/4in (45mm)
- Plug Length 0.75in (19.5mm)
- Plug diameter: 0.13-0.18in (3.4-4.7mm)
- Outside Diameter (sleeve): 0.4in (10.5mm)
- Inside Diameter (sleve): 0.34in (8.5mm)
- Sleeve lenght: 1in (25.5mm)
- Outside Diameter (connector): 0.3in (7.7mm)
- Inside Diameter (connector): 0.17in (4.4mm)
- Connector depth 0.59in (15mm)
