I'm trying to decide between the Klipsch RP-4000f and Klipsch RP-600m for my left and right speakers in a 5.1 set up. I don't have much space width wise, and these two models are some of the only speakers that will fit in the space that I have. If I were to choose the RP-4000f floor-standing speakers, they would be pretty closely sandwiched between a subwoofer and my AV stand (with about 5cm on either side and about 15 to 20cm behind). With the RP-600m bookshelf speakers, they would be sitting on stands which would raise them just above the height of the subwoofers, which means they would much more space directly behind them. So with regards to the rear ports on either model, I'm not sure which one I'd be better off with.
Other factors include that the centre speaker I'm likely to get is the Klipsch RP-400c as it's about the only speaker in the Klipsch range that will fit in my AV stand (where the shelf height is about 19cm and is rated to hold a maximum weight of 10kg - although I don't know how much leeway AV stand manufacturers allow with these weight figures). Also because the RP-400c is only about 15cm high, I would have space enough to tilt this centre speaker upwards, so that the tweeter fired directly towards my ears in the MLP. Would the RP-400c be a better tonal match for the RP-4000f speakers?
On the flip side, I've also heard that because the RP-600m has a bigger waveguide, it can produce a larger soundstage than the RP-4000f.
Any help deciding would be most appreciated.
