Klein's Software Update Released
ConnecTEDDD
Klein ChromaSurf 5.10.471 (25 April 2014)
Added Features
*Flicker
- Removed Roll off
- Added Signal graph
- Added RangeLock
- Added Save one Shot
- Added Save the current Flicker
- Added when paused, can between switching units
- Added Flashes
- Added Logging Flashes
*Main window
- Removed Flicker from window, added a new window for flicker
- Added Save the current Measurement
- Added more IRE Steps, from 5 - 100 every 5 steps
- Added Auto connection to the previously Klein Device that was connected
- Added a Max White Y adjustment setting
- Mapped the target color to the Test Panel
- Added Video/Broadcast mode for easier calibration
*Test Panel
- Removed Flicker
*System
- Added Day Theme
- Unit text boxes will resize
- Added decimal points to Max White Y
Bug Fixes
*Create Cal
- Fixed repeating last color
*Main Window
- Fixed Slow Connections
*System
- Corrected Sony's offset
- Added Nits/fL to Logging, Kelvin Calc, and TestPanel
- Fixed a crash on closing ports in Create Cal, and other similar forms
Tested Linux platforms:
* CentOS 6
* Ubuntu 13
Download Link
ConnecTEDDD
Klein ChromaSurf 5.23.532 (23 June 2015)
Release Notes
VerfiyBlack: aiming lights check
WhiteOffSets: Changed "Sony" to "Sony OLED"
Flicker: Added Colorimeter connection options
Gamutspec: Changed tolerance for white offsets
MainWindow: users can click on Flicker before Klein device is hooked up
MainWindow: Fixed an xy issue on Magnified mode
MainWindow: Add offsets settings
MainWindow: CalFil 0 will display on startup
CreateCal: Fixed crash on Switching devices
CreateCal: Fixed bug on closing form and close Klein Device
CreateCal: Fixed bug on getting measurements from Klein Device
Download Link
ConnecTEDDD
Klein ChromaSurf 5.36.551 (16 December 2015)
Release Notes
Mac: Fixed a connection bug
Mac: Fixed a saving profile bug
Mac: Fixed a QC profiling bug
Gamutspec: Fixed DCI-P3 White point
Gamutspec: Fixed offset not applying on startup
Mainform: Fixed an averaging display bug
FlickerForm: Fixed the signal graph when no K-10 is hooked up
CreateCal: Updated the PatternManager
PatternManager: Changed the UI
Themes: Fixed a few issues
Download Link: Klein ChromaSurf
Hixs
If I wanted to attempt to calibrate my TV with this knowing nothing about most of what I just read on the website, would I fail miserably? :D
My TV has pretty bad light bloom, which is especially noticeable when credits roll on black backgrounds. I want rid of that. I have it set in cinema mode currently.
ConnecTEDDD
Klein Software is for Klein Colorimeter Meter users only.
There a lot of other calibration solutions to check, to calibrate using your available internal display calibration controls.
Below you can find very good guides to get a better idea what you can do with display calibration.
Video Calibration
Video Calibration From The Inside - Volume I - 2nd Edition-1
ChromaPure Video Calibration Software
http://chromapure.com/ChromaPureManual.pdf
http://www.spectracal.com/downloads/...n%20How-To.pdf
User Guides
Webinars
SpectraCal
Light Illusion
Light Illusion
http://lightillusion.com/manual_cali...ots_guide.html
If you want to try a calibration disk, take a look: Ted's LightSpace CMS Calibration Disk
Hixs
Cheers bud!
ConnecTEDDD
Klein ChromaSurf 5.43 (04 January 2017)
New Features
Test Color Batch allows users to set up color patch timelines.
Profile selection for CS.
Arrow keys now navigate between colors on Pattern Gen Window.
Added the resolution of the Patch Sizes on Pattern Gen Window.
Faster way to check Klein devices.
Faster way to check for PR-650 devices.
Faster way to check for CS-2000 devices.
HI-DPI buttons.
Antialiasing on Graph.
Updated the UI for Flicker and Main Forms.
Added Max averaging for auto low light.
Added auto for low light for averaging on Pattern Gen Window.
Added Faster Measuring Mode.
Allow users to log more than one time in Flicker log.
Kelvin Calculator can convert from LAB to any other measurement by using spectro.
Added loading iris when doing black calibrations.
Flicker Auto lock.
Deleting profiles requires password.
Crash Fixes
Sending images without a Pattern Gen hooked up.
Mac: selecting a device.
Mac: rescanning for a device.
Clicking QC save data when there isn't any data.
Bug Fixes
Labels and LineEdits able to resize better.
Changed nits to Lux when using Lux profiles.
Memory leaks.
Kelvin Calculator graph now updates on a gamut change.
Better locking for Mac.
Using RAW XYZ instead of corrected XYZ for averaging.
Units in Manual Entry.
Download Link
ConnecTEDDD
Klein ChromaSurf 5.53 (01 November 2017)
Bug Fixes
Flicker Form reset workspace on opening.
Updated copyright year.
Autoconnect to last Klein device on startup.
Fixed smoothing.
Fixed first Hz value.
Download Link
