Klegg M8-5.01
Discussion in 'Home Cinema Speakers' started by F G Evans, Jan 7, 2005.
  1. F G Evans
    F G Evans
    Has anyone heard of these speakers - they are available for £90 at my local hi fi store.
    I can not find any info on these whatsoever.
    I am in the process of buying the yahama RXv650 AV RECEIVER and want to know whether these will work ok with that system.
  2. garyjd
    garyjd
    Nov 9, 2004
    163
    16
    Sydney
  3. Zigster
    Zigster
    Jan 5, 2005
    108
    16
    If your local hi-fi store is Richer Sounds, call them to check that they actually do have the speakers in stock! I found this deal on their website and called the Maidstone store to check - apparently they've lost most of the bits and its just the sub-woofer. Suddenly, not such a good deal!
    If you can find it at a decent price, I'd say buy it. They look great and What Hi-Fi gave them 5 stars. Look at the maker's website, www.klegg.com, which gives hook-up diagrams - I think they'll work with any AV receiver, although the What Hi-Fi review used the Klegg AVR 618 receiver.
    PS. If your local hi-fi store isn't Richer Sounds, could you post the name of your store as I fancy a set myself.
  4. F G Evans
    F G Evans
    yes it was Richer Sounds and yes it was only the sub-woofer they had in stock
