Question KK Q125 cross over frequency
Discussion in 'Home Cinema Speakers' started by UMAR 3:16, May 16, 2018.
Tags:
  1. UMAR 3:16
    UMAR 3:16
    Feb 9, 2005
    4,565
    3
    107
    +313
    hi all,
    Running the KK Q125LCR with the Onkyo 876. What should the cross over frequency be set too? After running setup it was full range but I have changed this to 120htz. Is that ok or should it be 80htz THX.
  2. Russ 66
    Russ 66
    Jan 5, 2004
    1,988
    116
    Norfolk
    +1,441
    120hz seems a little high, I would try 80-90hz.
    Best bet though is to try several different cross overs and use the one that sounds best.
  3. UMAR 3:16
    UMAR 3:16
    Feb 9, 2005
    4,565
    3
    107
    +313
    Thanks russ. I’ve set it at 90hz now. Although it states 80hz as thx.
  4. UMAR 3:16
    UMAR 3:16
    Feb 9, 2005
    4,565
    3
    107
    +313
    Another question, there are 4 connections on the back of the speakers, I have used the top two black and red for connection. Is this correct or am I missing something?
  5. Russ 66
    Russ 66
    Jan 5, 2004
    1,988
    116
    Norfolk
    +1,441
    There are two sets of connections for biamping/biwiring. If you are not doing this one connection is fine just make sure there are jumpers between the connectors.
  6. UMAR 3:16
    UMAR 3:16
    Feb 9, 2005
    4,565
    3
    107
    +313
    But I can choose any connection I like correct? As positive and negative
  7. Russ 66
    Russ 66
    Jan 5, 2004
    1,988
    116
    Norfolk
    +1,441
    Yes as the bridge plates have physically connected both - and both + together respectively.
    There is a KK thread somewhere on the speaker forum, it might be worth finding it, lots of useful info.
  8. Member 769353
    Member 769353
    Previously davidf
    Nov 2, 2016
    1,410
    116
    birmingham
    +753
    After having a play about between 60 and 70 (usually had it at 80Hz), I settled on 70Hz as the system sounded a bit thick at that point with the sub doing it, so I let the speakers do it, and that sounded more balanced. The speakers had decent output at 70Hz in my room.
