Kitchen speaker recommendation
Discussion in 'Home Cinema Speakers' started by MarkHudds, Apr 15, 2003.
  1. MarkHudds
    MarkHudds
    Jun 12, 2002
    548
    +4
    I'm after a pair of reasonably priced speakers to sit on top of my kitchen wall units. There's about 30cm height to play with.
    Power will be delivered via the B speaker output of my Pioneer AX10.
    Any recommendations?
  2. wookie
    wookie
    How about a pair of KEF "Eggs".
  3. nathan_silly
    nathan_silly
    I'll use speakers designed for greasy/humid environments.
    Maybe a set designed for outdoors?
  4. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    Anything from Richer Sounds that's the right price ... older Missions or KEF Crestas maybe.
    The accoustics of a kitchen are never going to be stunning so no point worrying about getting high quality. Also as Nathan said there is potential for greece, etc so if you buy cheeper speakers than you're not going to worry about them so much if they do get damaged.
    Vikki
  5. nathan_silly
    nathan_silly
    Hmm I wonder what speakers are big enough for Greece to fit into? :)
  6. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
  7. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    I don't think fully weather proof speakers are necessary in a kitchen ... just get a set of speakers that arn't too expensive so if they did get damaged you won't be too out of pocket.
    A pair of KEF Cresta 1, or Mission 701e would be perfectly adequate given the required location, etc ... if they're too tall just put them on their sides.
    Vikki
  8. MarkHudds
    MarkHudds
    Jun 12, 2002
    548
    +4
    Hey! I (well the missus) cleans the kitchen on a regular basis - it's not that greasy! ;)
    Anyway, many thanks for the suggestions ... I'll do some research!
  9. dunkyboy
    dunkyboy
    Jun 5, 2002
    633
    London
    +6
    If you were after something a bit classier you could stick a pair of Gallo Micros up on the wall somewhere (where they'd be out of the way of potential spillages, but still visible :) ). Naturally wouldn't have hooge bass, but I'm guessing that's not really necessary in the kitchen. :)
    Dunc
  10. Nobber22
    Nobber22
    Jun 6, 2002
    2,979
    Berkshire
    +110
    Get a set of small FRONT PORTED bookshelf speakers like the Mission 700's for around £50 at RS. Rear ported designs will boom on the top of a shelf with so little space.
  11. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
  12. nathan_silly
    nathan_silly
    You'll probably best to go for speakers with a plastic cone, not paper (it'll rot, and maybe go soggy with kitchen moisture)
  13. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Don't think that would be too much of a problem. Don't forget car in door speakers were origionally paper and they didn't seem to suffer
  14. Sunday Ironfoot
    Sunday Ironfoot
    Get yourself a set of B&W 603 S3 floorstanders, they'll fit no problem :D
  15. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Thats just plain silly :rolleyes:
  16. nathan_silly
    nathan_silly
  17. Sunday Ironfoot
    Sunday Ironfoot
    lol, the description on these speakers is hilarious :D
    BTW, what wattage there these babies..err..brutes?
  18. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    Hey Nathan ... I think that answers your question ...
    Vikki
  19. Sunday Ironfoot
    Sunday Ironfoot
    I think he's referring to the cast from the musical.
  20. gilesm
    gilesm
    Aug 29, 2002
    179
    UK
    I've got a couple of KEF eggs (£100 each) connected to a Denon M30 in thew kitchen and the work fine, mine just sit on top of the cupboards without any protection - although they are at the opposite end of the kitchen to all the steam etc
