Kitchen Conversion & Speakers
Discussion in 'Home Cinema Speakers' started by Bluestu, Sep 18, 2005.
  1. Bluestu
    Bluestu
    Aug 8, 2002
    75
    Hello, I am currently having my garage converted into a kitchen and it struck me this afternoon that this would be an opportunity to install a couple of inexpensive speakers whilst the ceiling is removed.
    I want to use my Panasonic SA-PM01 midi system (hidden in a cupboard) which has a input for my Ipod. Then I want to mount a couple of round speakers in the new ceiling. However, as I know nothing about what's compatible and what I can do I would appreciate some advice as to where I can buy car type round speakers that are suitable for ceiling mounting in white. I've checked my Stereo manual and it says the current speakers have an input power of 30W (Music) and 15W (DIN)...does this mean I should buy 30W speakers maximum? It also says:-
    Speakers Full Range 10cm cone type
    Speakers Tweeter 6cm cone type
    Thanks - Stu
