Kit to go with PV500...
Discussion in 'Plasma TVs' started by CraigHolt, Jul 27, 2005.
  1. CraigHolt
    CraigHolt
    I am awaiting delivery of my PV500. I was hoping for some advice about the best kit (dvd, speakers etc) to go with it. I am currently favouring either Maranz Hollywood or Teak legacy 800 all in one systems (I don't like the wood effect with the denon). I would like a DVD player as part of the all in one that has component prog. scan and also, ideally, one that can upscale so that I can get the most from my new plasma. Can anyone help me as to whether:
    a) either of these systems have both of these features (my understanding is prog scan - yes, upscaling, no)
    b) if there is an all in one system for under £1000 that does?
    c) should I consider separates instead?
    All help gratefully received!
    Craig
    p.s. should I also be looking for a DVD player with a HDMI connection to get the best from my PV500?
