Kiss DP-550 DVD recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Goose74, May 20, 2003.
  1. Goose74
    Goose74
    Sep 24, 2002
    805
    Romsey
    +12
    does anyone have any info on this recorder - it looks good.
    Prog scan
    Can record 5.1 audio
    DivX recording to cd-r etc.
  2. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    I emailed Kiss about this player the other week. They still have not finalised the spec and could not tell me when it will be released though. I saw the machine at the cebit this year and wanted to order one straight away.
    You are right though Ringer it´s a great piece of kit, best feature imo is the capability of recording in Divx (mpeg 4) from the telly onto a cdr or dvd +/-.
    Only thing that could possibly make it even better would be the inclusion of a HDD. I suggested that to them and they said they were looking into it.
    Can´t wait:smashin:
  3. Goose74
    Goose74
    Sep 24, 2002
    805
    Romsey
    +12
    I am very hopeful about this product.
    Am I right in thinking that it outputs pal prog too? Component outpus? If it would record to DVD plus as well as minus it would be killer.
    The concept of recording onto cd-r/rw in DivX is genius - very cheap media.
  4. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    They told me at the cebit that it would do pal prog not sure about component conections. Also it will record on all dvd recordable formats except ram.
    If I get any more updates I will post them for you:)
  5. Goose74
    Goose74
    Sep 24, 2002
    805
    Romsey
    +12
    cheers sick note - I appreciate it
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,221
    Argyll
    +2,268
    Where did you hear this from? The press release I got from KISS said that it will have component input/output and will record to DVD-RW, DVD-R, CD-RW and CD-R only.
  7. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    Got it from the mouth of a guy on the stand at the cebit but he said then nothing was certain,just passing on what I know.
    Guess we all just have to wait and see.
    Forgot to mention that if you have a sky+ box you can record a film with the 5.1 track intact as the 550 wiil have digital inputs for this
  8. encaser
    encaser
    Mar 15, 2001
    1,566
    Suffolk/Essex
    +112
    Will it fit on a disc though? I'm assuming divx will but not mpeg2.
  9. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    It will fit on a dvdr using mpeg 2 or divx. Will probably have to use multiple cdr discs when recording in mpeg2.
  10. Bassbin
    Bassbin
    Mar 16, 2003
    2,395
    48
    Leicester
    +56
    This sounds very promising.
    I recently bought a Kiss Coolview monitor to use in a bedroom. The display quality is only average but the design of the unit is fabulous.
    Just a shame that Kiss stuff seems only to be available from mail order computer suppliers - be nice if they could sign a distribution deal with Richer Sounds or another chain.
  11. joshua_bond
    joshua_bond
    Jun 25, 2002
    342
    +16
    Lads,
    the only thing to add is that it is about 400 according to Home cinema choice.
