KiSS DP-1504 Any comments or views before I consider it?
Discussion in 'Blu-ray & DVD Players & Recorders' started by DannyLizard, Nov 1, 2004.
  1. DannyLizard
    DannyLizard
    Hi all,
    Well I’ve just had a disastrous trial of the D-Link DSM-320 PC to TV media centre, I wont bore you with the details but it went back to the original suppliers today (a nasty little gadget I must say :suicide: ).
    I’m considering the KiSS DP-1504 to playback all my PC based media (AVI, MPEG, DIVX & XVID files) through my Sony TV and also tap into the PC connectivity & broadband use through it, but mainly for the video file use.
    Has anyone got this machine? Or a KISS DVD player? I would love to hear the views of the forum b4 I consider the purchase of it.
    Thanks Danny.
  2. DannyLizard
    DannyLizard
    Well i supose no news is good news?
    Danny.
  3. smithgi
    smithgi
    Nov 5, 2004
    10
    Kiss are about to release their 600 series. I got a reply from their sales team saying they are going to leaunch the dp-600 in europe in January for about £250.
    It will do everything under the sun, including playing hi-def WMV9 and DIVX at massive resolutions.
    check it out on the KISS web site.
    Gav
  4. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    would that be the same DP600 that was supposed to be released in July 2004 by any chance?
    KISS are famous for non-delivery. I'd say buy something that actually exists rather than vapourware.
  5. poggs
    poggs
    Jul 21, 2004
    638
    28
    +30
    I bought a kiss 1000 as a bedroom player, but found it gave me a better picture on my hitachi plasma than my 'main' player, a Harman Kardon 25 so it is now the 'main' player! I bought it primarily for Divx playback but have been pleasently surprised by its overall picture quality. it does have bugs which require a hard power off on occation but they have only appeared when I have fast forwarded Divx cdrw of a dubious quality. then the whole dvd player locks up requiring the plug to be pulled. I'd recommend one. However I would state that I have never seen a pioneer 470 in action and can only compare the kiss to older machines that I have seen and owned.
  6. BestGear
    BestGear
    Oct 22, 2003
    1,261
    +48
    I have two Dp 508s and love em!
    They have had firmware issues - most of which you will never experience so dont let that put you off.
    The box has a linux kernel, so you can do all sorts with them.
    They have a 10/100 ethernet onboard... and the 508 version has an HD - although you can add the HD to a 500 if you wat (500 and 508 are the same bar firmware revisions...)
    If you are looking at them, best go for EZLINK as the server side software - much better than Kiss's effort!
    Great products and nice and easy for the rest of the family...
    David
  7. Famished
    Famished
    so will a normal network cable be used to connect the PC to the player. I assume there is a network card already installed?
  8. Famished
    Famished
    this model aslso looks good KiSS DP-1500 not sure if I actually need the HD space on the machine as I have got 500GB on my PC.
  9. smegleyshire
    smegleyshire
    Mar 14, 2005
    10
    3
    Danny,
    Also just sent back my Dlink DSM-320. It couldn't cope with MPEG-2 TV recordings made on my PC even when wired rather than wireless.
    After digging around, found that Buffalo are planning on releasing a box in the UK which is currently available in Japan and the USA. It is based on a certain sigma designs chip and is specced to be able to handle high bitrate video (including WMV9) and up to HD resolutions. All that plus it's got a DVD drive and USB port that it can play media files from as well...
    Go to www.buffalotech.co.uk and look under wireless products - you'll find it at the bottom of the page.
  10. tcp/ip
    tcp/ip
    Jul 17, 2004
    249
    +39
    I am trying to order one if the buffalo players anybody know anywere in the UK that sells them
  11. rob_webset
    rob_webset
    Dec 5, 2007
    26
    3
    I have actually got 3 DP-1504, (2 upgraded to 80Gig).
    I actually think they are pretty good - pretty cheap on eBay if you find one.
    I suppose it depends on if you wanted to use wireless or not - if you want wireless on one of these boxes - then forget it! - It kept crashing out whenever I tried to ftp to it.
    I now have them set up via those home-plug things - and everything works great.
