Quantcast
Kiss DP-1000-SFF DivX DVD Player
bonzobanana
This forum will give you lots of info;
http://www.gooddvdstuff.com/kissdvd/index.php
I personally prefer the kiss DP-450 (which I have ). As you can crash a kiss player when you try some divx/xvid material which isn't fully compatible and with the above model you have to turn it on and off at the mains but with the 450 there is a front facing on/off switch on the player itself.
I personally think the kiss player with its current firmware offers just about the best dvd picture going at any price and divx/xvid compatibility is very good indeed. Its a bit eccentric in some ways, for example there is no slow motion mode only frame advance but generally an excellent machine.
M
mikeq
or the DP-500 which has a network card in it, you can stream your DivX etc from a PC.
