Ok so this is what I have put together so far, think it covers everything
If this seems ok then I think I will set these as the Perks/Weapons/Streaks for the Challenge
If a perk does not list its Pro Ability then its becausee you would have to use a gun to get it.
The Following Weapons & Equipment are the only things you are allowed to use and unlock in this Prestige.
From Level 1 > Level 50 only the below can be used.
Setups
Specials
Ballistic Knife – Unlocked Level 13
The Crossbow – Unlocked Level 33
Normal Knife – Unlocked From The Start
Launchers
M72 LAW
RPG
STRELA-3
Lethal
Frag
Semtex
Tomahawk
Tactical
Nova Gas
Flashbang
Concussion
Equipment
C4
Claymore
Perks
Choose 1 Perk from each Slot from the following
Slot 1
Lightweight
Ability: Allows you to move faster.
Pro Ability: No falling damage.
Scavenger
Ability: Replenishes your ammunition and lethal Grenades.
Pro Ability: Doubles your starting ammo with extra magazines. This also replenishes your tactical grenades.
Ghost
Ability: Cold Blooded
Pro Ability: Undetectable by aircraft, infrared and sentries
Flak Jacket
Ability: Flak Jacket greatly reduces explosive damage and allows you to survive any indirect explosive attack.
Pro Ability: Deflects fire damage and allows you to reset the fuse of a thrown grenade when you pick it up.
HardlineAbility: Reduces the amount of kills required for any killstreak by one.
Pro Ability: Allows you to randomly choose another reward from a Care Package.
Slot 2
Steady Aim
Ability: Steady Aim increases a weapons hip fire.
Pro Ability: When equipped, this enables you to aim faster after sprinting and recover faster from a knife lunge.
Sleight of Hand
Ability: Gives a faster reload time by reducing your weapons reload time in half.
Slot 3
Tactical MaskAbility: Protects you against NOVA GAS.
Pro Ability: Tactical Mask Pro reduces the effects of flashbangs and concussion grenades.
Marathon
Ability: This extends your sprint time.
Pro Ability: Gives you unlimited sprint.
Ninja
Ability: Ninja allows you to walk, sprint and jump almost silently.
Hacker
Ability: Allows you to see enemy explosives, equipment and Tactical Insertions.
Pro Ability: Hacker Pro actually allows you to sabotage enemy Care Packages and also turn enemy equipment friendly. This also makes you invisible to Motion Sensors.
Killstreaks
Pick 3 Killstreaks From The Following
3 - Spy Plane
3 - RC-XD
4 - Counter-Spy
4 - SAM Turret
5 - Care Package
11 - Attack Dogs
