kinect not recognising the word yes when trying to shutdown
Discussion in 'Xbox One Accessories' started by techno59, Feb 24, 2014.
  1. techno59
    techno59
    May 20, 2008
    670
    2
    +73
    has anyone else had the above since update , my x1 and my sons doesn't respond when trying to shutdown , it worked before update ??
  2. shuflie
    shuflie
    Oct 4, 2007
    219
    +59
    Works for me.
  3. TayWax
    TayWax
    Sep 26, 2013
    9,437
    +7,098
    Mine went through a phase of not recognising anything I said. Found a fix online. Hold down power for 10seconds to power off. Then unplug Kinect. Turn back on and go to Kinect settings. Plug Kinect back in and it worked normally after that
  4. DonnySteve25
    DonnySteve25
    Sep 18, 2004
    281
    Doncaster
    +32
    I had the same problem & that seems to have fixed it for me so thanks for that.
  5. iwb100
    iwb100
    Feb 28, 2011
    8,889
    163
    +4,216
    Same for me. Since the update. Every other voice command works perfectly. Just that one.
  6. techno59
    techno59
    May 20, 2008
    670
    2
    +73
    yeah mine and my lads exactly the same problem , every other command works great except that , now ive just tried a power down then back on , go to power settings and switched to energy efficient it worked that time but will see
