Kindle Fire any good as ereader?
Discussion in 'General Tech & Gadget Forums' started by Cunny, Sep 7, 2012.
  1. Cunny
    Cunny
    Feb 21, 2005
    131
    +7
    Can anyone with experience of the Kindle Fire tell me if it's any good as an ereader?
    I have an ipad and an old keyboard kindle, as the kindle is a far better ereader due to it's non-reflective screen.
    Does the Kindle Fire still work well as an ereader now it's added all the other functionality?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,471
    2
    +1,365
    The reason the Kindle works so well is that it uses Black ink tech. I have never seen a colour screen work in bright sunlight.
  3. rockmonkey1973
    rockmonkey1973
    Mar 26, 2008
    3,923
    103
    +263
    mate it isnt out till october so no one is gonna tell you on this forum how good it is. however you might find a few hands on reviews on tech sites if you do a quick search.
    i will say this even though i aint touched one on the flesh i can already tell you it wont be anywhere near as good. Using any sort of tablet be it an ipad or a cheap chinese jobby is just not gonna compete with a real ereader. the e ink screens on proper readers are just so so so so much better for reading in sunlight.
    if however you never intend to take it outside you will be fine because in my experience the apps on tablets are great and they certainly handle pdfs way way better than normal ereaders.
    bottom line tablets work well inside (although backlit screens tend to hurt peoples eyes after a while a problem mostly avoided with e ink) but if you intend to read outside then get yourself a dedicated ereader... well actually my advice is to get yourself a kindle reader and get a kindle tablet as well. best of both worlds then.
  4. anika hanson
    anika hanson
    Feb 19, 2010
    316
    28
    +33
    Not to mention that the battery life will also be much better on a dedicated e-reader. You can get up to a month on a single charge. On a tablet you are looking at around a day per charge. The fire is also a tablet with an LCD display and will perfom just as good or bad as you ipad does for reading.
  5. tonycommander
    tonycommander
    Nov 1, 2004
    2,078
    Malvern
    +159
    i have one...
    bought it off here strangely enough!
    as an e-reader ( and i have owned 2 sony's, an original kindle and an ipad ) it's ok.
    outdoors in sunlight a proper dedicated e-reader will beat it hands down.
    as a cheaper smaller ipad replacement - it's great... seems to be lots of content in the kindle and android stores - you can install a dedicated android rom on it if you wish.
    for me, works great as an e-reader on the train and isnt as obtrusive as my ipad so i dont feel self concious using it.
    the fab thing for me with any kindle device or app is the whisper sync technology that saves my last read page to any device...
  6. Cloysterpeteuk
    Cloysterpeteuk
    Feb 5, 2005
    4,776
    Whitby, North Yorkshire
    +1,106
    I wonder how many years it will be before someone makes a OLED (or whatever it will be then) screen that looks just as good outside as it does inside, my iPhone screen is invisible in bright sunlight. Good challenge for the boffins to make one - preferably in my lifetime.
  7. larkone
    larkone
    Apr 21, 2006
    4,228
    134
    North Essex
    +1,149
    Have two tablets and a smartphone that can all run Kindle reader but none are as comfortable to read as my Kindle reader because of the reflections and backlit screens. If you are a serious reader then a proper Kindle reader is the way to go.
