Kiln Dried Sand
Discussion in 'Home Cinema Building DIY' started by gazzawales, Jan 10, 2008.
  1. gazzawales
    gazzawales
    Jan 2, 2008
    34
    Penygraig, Rhondda
    Any ideas where I can get kiln dried sand from? I want to put some in my Nexus 6 speaker stands.
    I've tried all the usual suspects (B&Q, Focus, Travis Perkins, Leekes and local builders merchants) and they all say either that they only stock it in the summer or that they don't sell it anymore!
    Other than that, has anyone any other suggestions as to what I can use please.
    Help!!!
    Thanks,
    Gaz
  2. dbs2
    dbs2
    Jun 28, 2006
    1,596
    Sunny Norfolk - uk
    +196
    Can you not stick some normal sand in a fan oven on a low temp ?? :rolleyes:
  3. Beaker
    Beaker
    May 4, 2002
    96
    11
    York
    +7
    Try toy shops like Toys R Us as they may stock it for kids sand pits.
    Beaker
  4. dj-dulux
    dj-dulux
    Dec 29, 2006
    1,247
    Kenilworth
    +151
    B&Q used to sell it, have you tried the bigger warehouse ones?
    Dupe...
  5. Fieldling86
    Fieldling86
    Jan 3, 2008
    61
    +4
    I think most builders merchants will stock it as it is fine sand used in block paving.
    Per
  6. gazzawales
    gazzawales
    Jan 2, 2008
    34
    Penygraig, Rhondda
    Thanks for the replies.
    I think I'll try Toys'r'Us as I've done all the builders merchants etc including a large b&q.
    If I have no luck, then I'll just wait until the summer!
  7. dj-dulux
    dj-dulux
    Dec 29, 2006
    1,247
    Kenilworth
    +151
  8. Event Horizon
    Event Horizon
    Oct 30, 2007
    3,854
    Northants
    +498
    hi!!
    sliver sand is worth asking for its basically the same but perhaps using a different name will get better results. i am a stone mason and use various sands and most of the builders merchants stock that in this area so i do find it strange that you are are indeed strugling.
    best regards
    nick.
  9. stevey27
    stevey27
    Jan 13, 2007
    147
    +5
    i use it most days in my job and i must say i've never struggled to get hold of it as klvcarplake has said try asking for silver sand instead
  10. gazzawales
    gazzawales
    Jan 2, 2008
    34
    Penygraig, Rhondda
    I'll be off to B&Q as soon as they open!
