Kill Bill 2: R3 v R1
Discussion in 'Movie Forum' started by saibot, Aug 25, 2004.
  1. saibot
    saibot
    Jun 28, 2004
    1,240
    Near the Lee - Ireland
    +42
    Hi all,
    cdwow.ie/cdwow.uk now have the R3 release of Kill Bill 2. which is some what cheaper than the R1/R2 releases. Its also a 2 disc (DTS) set.
    However the R1/R2 releases say they have some deleted scenes, any-one know if these are on the R3 release as well ???
    ta,
    donnacha...
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    donnachaoc:
    Have a look here.......
    http://www.dvdcompare.net/comparisons/film.php?fid=5845
    Even 'tho there is a deleted scene, there is no cuts ?? :confused:
    Does that mean that the same scene is cut from all versions ??
    I've got the R1 version, and it a top disk. :thumbsup:
    Well untill the full uncut film makes an apearence..... :smashin:
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,860
    2
    In a secret location with Jennifer Lawrence
    +9,720
    Moved to DVD Comparison forum
  4. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Don't panic. It is perfectly normal for certain scenes never to make it into the director's final cut of the movie - you're not missing anything! It's purely a bonus that the cut scene is available on DVD for us to see.
    HTH
    Joel
  5. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Thanks Joel,
    Just thought it might be ANOTHER version at a later date ?? :rotfl:
    Cosmic023
  6. magicmushrooms
    magicmushrooms
    I agree the scene your are talking about is extremely cheesy and I'm glad it was removed from the film.
