Kies transfer data from iPhone 4S to Samsung Galaxy S3 i9305
zillah
Hello Experts
I have recently purchased Samsung Galaxy S3 LTE 4G (i9305), prior of using Samsung galaxy I was using iPhone4S (doesn't have any encrypted data).
I want to transfer all my contacts, SMSs, MMSs to my new phone.
I am using windows 7 64-bit
I tried to follow the procedure below :
SAMSUNG
How to transfer contacts from iPhone 4 to Samsung Galaxy S3 - Future Hardware
1: Before starting take a backup of all of your data and save on your system.
2: Start Samsung Kies-> Connect Your SGS 3 ,plus stay connected to your tab as well.
3: Goto Main page -> Select (basic summary) something similar to this.
4: At the base of your screen you can see : Transfer your BackUp data from Non-Samsung Device
5: You also have to select iphone 4 backup
6: Select the files you need to transfer to SGS3
7: Transfer
The error message that I am getting is
Cannot read the backup file information. Please select a valid backup file.
Same error in the link below
[Q] Using Kies to transfer iPhone backup (SMS, Photos) - xda-developers
Can you advise what should I do to overcome this issue ?
Mr Wolfe
zillah said:
Hello Experts
SAMSUNG
Check that iTunes is not encrypting the backup.
Mr Wolfe
Also in that link you posted it says you need to deselect 'Memos' as Kies cannot transfer these from iPhones, have you tried that?
AndyStella
I don't know a lot about Kies, when I started to use it, it ended up being worse than iTunes. Is it possible to extract everything from your iPhone backup and then dump it onto the phone, and then from the phone import everything to where it should be?
Andy
zillah
Hi Guys
It is not encrypted
Thanks for that , this was the problem.
I did deselect this option and I was able to proceed with backup except I wasn't able to get all SMSs ,,,any isight for that ?
Regards
sparkie1984
I use easy phone sync, it's an app and software for your pc.
It copied all my contacts probably thousands of texts and more.
Kies is rubbish mate
zillah
Do you mean SMS and MMS ?
Regards
Mr Wolfe
Hi Guys
It is not encrypted
Regards
Cool, glad it's sorted!!
Jay Z
Why don't you just use the apple backup file and then through Kies 3 just restore using the apple file?
