Question Kids Room 20” Smart TV
Discussion in 'LCD & LED LCD TVs Forum' started by Easybourne, Jul 25, 2018.
  1. Easybourne
    Easybourne
    Apr 7, 2005
    249
    Exeter
    +19
    Hi, I’m not sure if such a thing is available but I’m looking for a smart TV for a kid’s room. There is no aerial point (and it’s a terrible reception area anyway)
    Ideally, I’m looking for:
    * No more than 22”
    * Smart TV (Ideally WiFi-enabled)
    * iPlayer, ITV Player, All4, etc
    Any other bells and whistles would be good, but the three above are essential.
    It’s mostly to be used for watching CBeebies and as a general ‘noise maker’ for morning routines, so as long as it isn’t completely unwatchable, quality doesn’t have to be fantastic.
    Any ideas would be appreciated! Thank you!
  2. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    It is unlikely that you will find a Smart tv with this size of screen. As you have no aerial connection your best bet will be to plug in a Amazon TV Firestick to make your installation 'smart'. Be warned that your youngsters might soon find out how to use the Alexa facility available on the most recent Firestick.
  3. gibbletts
    gibbletts
    May 29, 2016
    42
    11
    U.K.
    +17
    Samung do a 22 inch and if you can go up to 24 inch there’s LG and a few others
  4. Analysis
    Analysis
    Feb 15, 2018
    1,737
    +310
    A monitor, android box and speaker set are good options overall, most of these small 20" tv's and upwards share the same internals, just that the tv's have some extra picture processing and tuners added.
