KHT 2005.2 Newbie Advice Sought
Discussion in 'Home Cinema Speakers' started by Peter Wright, Sep 19, 2005.
  1. Peter Wright
    Peter Wright
    Can someone please advise me the best way to connect my sub to the amp? I have a subwoofer cable with only one jack plug. Where do I put it? Do I need a Y Cable? Thanks
  2. BeelzebubUK
    BeelzebubUK
    Feb 19, 2004
    595
    Milton Keynes
    +24
    I'm no expert but I've already read 2 posts when looking up about subwoofer cables that mentioned this and the expert opinion was that it doesn't really matter which input on the subwoofer you use and a Y connector is not needed at all.
  3. Peter Wright
    Peter Wright
    Thanks mate, much appreciated :thumbsup:
  4. BeelzebubUK
    BeelzebubUK
    Feb 19, 2004
    595
    Milton Keynes
    +24
    I just reread the thread I saw about this and the manufacturer may recommend either the left or right if you're only using one of them so might be worth looking in the manual to see if they mention it.
