Keystone correction
Discussion in 'Projectors, Screens & Video Processors' started by livaspy, Jun 15, 2019.
  1. livaspy
    livaspy
    Jun 15, 2019
    Athnes
    Hello, its the first post to the avforum and i have a question about an argument with a friend.
    Is the pj keystone correction affect the image quality (resolution)?
    A single user understands the difference of the image?
  2. gav_sw20
    gav_sw20
    Dec 30, 2007
    809
    2
    46
    +128
    Yes it affects the quality as it skews the image.
  3. Mark_a
    Mark_a
    May 27, 2005
    3,310
    +741
    If it was optical it might not, but as they all use digital methods it has to manipulate the screen resolution to bend the picture, so yes it definitely affects the resolution. The better question, surely, is does it affect the picture enough for you to notice, especially say with a 4k picture, where a few missed pixels might not be so much of a problem?
  4. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,409
    137
    Middle Earth
    +921
    Don’t use it, just align the PJ or use lens shift if you have it. Keystone if done digitally, if not set to zero you instantly loose 1-2-1 pixel mapping, which will reduce picture quality and sharpness and you’re more likely to get moire patterns..
  5. GaryB
    GaryB
    Nov 12, 2002
    5,396
    St Albans
    +1,307
    When I was at JVC, I did suggest they they add an on-screen warning, advising that picture quality would be adversely affected when Keystone was activated. It hasn't happened as far as I know.
  6. IWC Dopplel
    IWC Dopplel
    Sep 11, 2008
    4,069
    134
    BATH
    +574
    I agree with all of the above and do also make sure your screen is plumb this will help
    Projector Alignment
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,933
    The Borders
    +3,575
    Ideally you 'pixel map' your Source Output to the native pixel of your display, then ensure no overscan is applied.
    Use a Horizontal and Vertical 1 pixel wide black/white stripe test pattern - the on screen image ought to look uniform grey if you get it set correctly.
    Now tweak keystone and you will see how it affects the image.
    Joe
