Keyboard compatible with WinMCE remote?
Discussion in 'Computer Peripherals & Consumables' started by northernmunki, Jul 9, 2005.
  1. northernmunki
    northernmunki
    I've got a WinMCE remote and receiver on its way, is there wireless keyboard/trackpad which will work with the same receiver?
    Maybe i'm over complicating things, is the receiver is a standard IR port on the end of a USB cable so any keyboard would work. I like the idea of the BTC model.
