Hi Mr. Wilby & TheCrow,
I have not had much time to update you, but here is a quick status report.
KD have been working on the first update and I have now briefly tested a beta version of 1.14.
This expands the steps in "Picture Controls" from +-15 to +-45 and removes that problem.
A hot key has been added (remote button 0) for toggling the PAL Film mode on/off.
Remote control sensitivity is improved.
There was a problem with the remote sensitivity but KD are fine tuning now and should have the final version soon.
The RGB PAL problem is being looked at for the following release.
The firmware upgrade is very easy to do with a PC and the supplied cable.
Basically the same as upgrading any other video processor.
KD have continued to be helpful in this their progress in fixing these issues is, for me, a good sign.
