Key Digital component to RGB transcoder.
Discussion in 'Projectors, Screens & Video Processors' started by Bill, Jul 10, 2003.
  1. Bill
    Bill
    Oct 31, 2002
    548
    3
    Dungannon
    +46
    Can I ask what this would cost?
    Also can somone confirm this takes the RGB feed a DVD player to a crt projector. Sorry if it's a silly question.
    Bill
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    PM Gordon @ Convergent AV for prices.
    It takes the Component signal from the DVD player and convert it to RGBhv out on VGA.
    I have one that I use from a Denon DVD3800 to a Panasonic PT AE100 and it works like a charm.:smashin:
    Hans
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,001
    It takes the YPrPb signal of anything and turns it in to RGBHV signal of same resolution and frequency. I have no stock at present. If you want one fast I believe Roland@ B4 or Henry@ CRT Projectors may have them from stock
    Thanks,
    Gordon
  4. Bill
    Bill
    Oct 31, 2002
    548
    3
    Dungannon
    +46
    I havn't actually bought a projector yet; in the process of saving for one.
    i have my eye on one of Rolands; should be able to afford it in two months. The name of the projector is Emily and it shows a picture run straight form a DVD player using one of these.
    I'm trying to find out how much more I have to save.
    I'm dying to get my hands on this; just hope somone doesn't beat me to it.
    Bill
  5. franc
    franc
    Sep 12, 2002
    450
    Bucks
    +7
    Hi.
    I thought the component input needed to be progressive to enable the Key Digital Transcoder to convert it to RGB on VGA.
    Correct me if I am wrong.
    If it works with interlaced signals as well, it would be a very useful tool!
    regards FRANC
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,001
    Well, I've used it with JVC30,000 D-VHS tape deck. This outputs its on screen graphics at 480i. It works. So I'd suggest that the answer is.....yes.
    Gordon
