Kettle(?) style connector or 10m lead
Discussion in 'Cables & Switches' started by russ123, Jan 27, 2005.
  1. russ123
    russ123
    Jul 31, 2004
    832
    46
    South Of The River
    +110
    I am looking for a power lead for my projector (Infocus). It has what I refer to as a 3 pin kettle connector on it. This is the same as used on most monitors, pc's and some av separates. Does anyone know the correct name for these or even better where I can buy an 8m or 10m one with a 3 pin plug the other end or one that I can connect my own cable to?
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Maplins, probably.
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    What you are looking for is called an IEC socket, unfortunately I've not seen one on a lead that long. DIY will probably be your only route unless someone else knows another source.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As has been said, it's an IEC 320 connector and DIY is about your only option. It's not as daunting as it sounds, it just involves wiring a plug and the IEC connector is easier to do than the wall plug!
  5. russ123
    russ123
    Jul 31, 2004
    832
    46
    South Of The River
    +110
    :thumbsup: thanks everyone. I have found a rewireable one and will make my own.
