Kenwood System (90's) Setup Help
Scasian
Hey everyone!
This is my first post.
Basically, my dad had an old hifi system sitting in the garage so I tried my best to clean it up, connect it all up, and use it for my Sony PS-LX310BT.
I've got it to work for the two main speakers (Kenwood LS-E9), however, I can't seem to get the Kenwood Omni-7s to get sound out of it.
This is an old system so not sure if anyone is well versed in connecting this up.
I have two cables connecting up the B-E9 and C-E9L.
The two LS-E9s are connected to the B-E9 "MAIN SPEAKERS (8-16 Ohms)"
The two Omni-7s are connected to the "OMNI PRE-OUT" (doesn't have a rating).
The PS-LX310BT is connected to the "IN AV AUX"
To connect the cables to the Omni-7s, I loosened the screw to show holes to the connects and connected the open wire in the gap and tighten the screw.
I don't have any CDs or cassette players so I didn't connect them up.
Pictures attached. Not sure how bad the quality is when I uploaded it. I can reupload if unclear.
I apologise for the lengthy post, if it's not in the right place in the forum, or bad structure.
Paul7777x
I’m not sure why you’d want to get anything other than stereo sound from the hifi. Especially for a turntable.
And you do have it set up for stereo correctly (as far as I can see).
Personally I’d stick to straight stereo.
You might try to find a switch or slider on the front that selects between stereo and surround.
A photo of the front of the amp part would be helpful.
Jamie
I'm not familiar with the equipment but the output is labelled as pre-out so can't be used to connect directly to a speaker.
I suspect with you need to use the surround speak terminals to the left OR there is an extra component. maybe an optional component that uses those pre-out terminals.
Scasian
@Paul7777x I knew I forgot to attach some images. This is the front panels of each of them. Not quite sure what's the best setting for it right now.
Never owned a HiFi system so this all new to me and starting with my Dad's old system isn't great. I've been using a FiiO E9 for a very long time now.
@Jamie Think my dad originally had the Omni-7s connected to the surround sound, but didn't really do anything either.
My dad only used it for his CDs so don't think he actually got the Omni-7s working - but I could be wrong.
