Kenwood Receiver - low DD5.1 volume
Discussion in 'AV Receivers & Amplifiers' started by ndenbow, Oct 28, 2003.
  1. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    I know this equipment is getting long in the tooth, but I need to know if anyone has experinced a similar problem with either this or any other amp/receiver. I have a Kenwood KRF-V7030D.
    Whenever I play a DVD (or Sky+ DD) using a DD5.1 soundtrack, I find the mix is really quiet, especially dialogue. DTS and Prologic is fine, but this is really annoying. I usually have to increase my volume by at least 10db to listen to DD5.1. My wife keeps complaining that she can't hear what people are saying.
    Is this a hardware issue, or am I missing somthing here? I have tried both Optical and Coaxial (IXOS) cabling between my DVD and Receiver, but it makes no difference.
    Thanks.
    Nick.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,445
    United Kingdom
    +1,825
    Does the Kenwood have individual channel level settings for each mode (Dolby, DTS etc)? If it does, maybe the settings for Dolby are too low.
  3. agendrano
    agendrano
    Aug 27, 2003
    24
    If I use the analogue connection between my DVD and receiver (say playing CD or PL II) the level is quite high as compared to DD5.1 (same as your setting +10dB to compensate). Between DTS and DD5.1, the difference should be quite small + 3 to 5 db, DD5.1 having a bit lower level than DTS.
    I believe you do not have hardware problem.
