kenwood prob
Discussion in 'AV Receivers & Amplifiers' started by kernaali, Oct 31, 2003.
  1. kernaali
    kernaali
    my kenwood 6xxx allways shuts down when i watch dvds and theres lot of noise...when i turn volume down a bit then theres no prob....its really annoying...whats wrong with it? thx for advance!
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,444
    United Kingdom
    +1,821
    Sounds like you're driving the amp too hard and it's shutting down or you may have a speaker wire shorting out somewhere. Doublecheck all your speaker connections to make sure. Also give the amp plenty of ventilation, overheating will also cause them to shut down.
