Kenwood Mask - Display not working
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by w3dal, Jul 2, 2004.
  1. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Hi All,
    Anyone who owns or used to own a Kenwood Mask had this happen??
    Basically drove my car to work with the Stereo on no problems, popped out at lunch in the car no problems on the way home the display did not come on. So i took the face plate off put it back on and still nothing. The unit still plays fine but i cant see anything on the display.
    I did hear that the ribbon cable in these do go, so i reckon thats what happend to mine.
    Any ideas in cost if i send to back to kenwood??
    Dal
  2. hollie.weimeran
    hollie.weimeran
    Yes m8, same thing happened to me as well about a month ago. I made enquiries and it could just be that the display has failed. Local company wanted £20 just to look at it and up to £50 to fix it. If it's just the display it is possible to replace the front panel for about £40.
    The annoying thing was, up 'til Christmas we had two of these (one in wifes car as well). Wife swapped her car and I swapped the cd player as hers was the newer model AAAAAAARGH!
    Me.........I'm just using it as it is, I know what all the pre sets are, unless you are someone that alters the equalizer settings or messes with the menu functions you'll soon get used to the blank screen.
  3. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Hi Mate,
    Its a common fault on these head-units. I have managed to find a company who will replace the ribbon cable and post it back to me for £25.00
    Should hopefully have it back tomorrow, let me know if you want yours done and ill send you the info. Guy was very helpfull
    Dal
  4. hollie.weimeran
    hollie.weimeran
    Thanks for the info, let me know how you went on and the details of the company. I may decide to get it fixed.
  5. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Hi Mate,
    Just put my Headunit back in after repair and all works perfectly. Would recomend this guy and for £25.00 might be worth getting yours done when your a bit flush.
    Let me know if you want anymore info on this guy
    Dal
  6. Zarch
    Zarch
    Jan 23, 2003
    3,552
    Sheffield
    +831
    Dal,
    What is this company and where are they?
    My 2 year old mask MP3 player has bitten the dust in the last week. :suicide:
    Worked on a off last week, sometimes sound but no display, but no just no anything.
    £25 sounds like a bargain compared to £150+ for a new one.
    Mick
  7. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Hi Mick,
    Drop this guy an email. He did a top job and really quick turn around nice guy too.
    Blue ICE Electronics · Mark Waller [[email protected]]
    His full info is -
    Blue ICE Electronics - In-Car Entertainment Specialists
    www.blueice-electronics.co.uk
    [email protected]
    Correspondence: c/o 7 Lansdowne Road, Purley, Surrey CR8 2PD
    Tel: (020) 8668 0728 . Mob: 077 7932 5985 . Fax: 070 7505 5342
    ICE Reference Site: www.blueice.org.uk
    All be best fella
    Dal
  8. Zarch
    Zarch
    Jan 23, 2003
    3,552
    Sheffield
    +831
    Can highly recommend this guy. :smashin:
    £25 including return postage.
    My mp3 mask was screwed. (no display, no sound)
    Came back with a new black back faceplate and the unit repaired.
    Saved me a packet :clap: :clap: :clap:
    Fantastic!
  9. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Glad u got it sorted, He is a top bloke and would use him again.
    Dal
  10. Zarch
    Zarch
    Jan 23, 2003
    3,552
    Sheffield
    +831
    Cheers for your help Dal. Would never have found him otherwise!
  11. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    No problems Fella, it was pure fluke a found him.
    Im sure others on this board will find him usefull with there Mask units go funny
    Dal
  12. andrewpurves
    andrewpurves
    I had the same problem as outlined by previous people. I emailed this guy and he responded really quickly. It cost £35.99 to fix my head unit, that included the recoded postage back to me (about £10). It cost me another £10 to send it recorded post, but for under £50 I was happy to get it fixed.
    Turn around was really quick, I sent the unit on Thursday, and got it back on Tuesday.
    I would highly recommend this guy if you have this problem.
  13. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Blimey i forgot about this topic.
    Nice to know that guy is still going strong. Come to think of it so is my kenwood mask - well my brother has it now with the car.
    Dal
  14. Kurt_Wylde
    Kurt_Wylde
    Oct 31, 2005
    461
    +21
    Just to keep this thread upto date, I've just mailed Mark and he's still doing the repairs, despite the website saying they don't..
    I'll be sending my dead headunit off to him tomorrow.. fingers crossed for an equally good result!
  15. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    can u PM me his email address please mate, one of the guys in my office needs the cable done.
    Ta
    Dal
  16. Kurt_Wylde
    Kurt_Wylde
    Oct 31, 2005
    461
    +21
  17. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    and you got a reply??
    ok i shall try again.
    Dal
