Kenwood KDC-5050R
Discussion in 'Video Streaming Boxes & Services' started by DITTRICH, May 23, 2005.
  1. DITTRICH
    DITTRICH
    I'm trying to find a downloadable manual from the net for this in-car cd-receiver. No luck so far. Any suggestions? It's a face-of design and not a current model.
    Also, am I right in thinking that it doesn't have to have a security code reinput if it loses its power - ie I need to disconnect the battery on the car and naturally I want the unit to work after I reconnect the battery :D .
    As you can see I'm not an expert, but I guess the manual would answer these questions if only I could find one.
    Les
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    You'd be wrong in thinking about the security code - assuming it's been set and is a feature of that model.
    When you disconnect power it's no different to thinking the unit has been removed (think - stolen) from the car. Therefore when reconnected, it'll ask for the code.
    As for manual, I can only find it listed on German sites - the UK Site has a manual for the 5060R (maybe the same unit but different model # in the UK?)
    http://kenwood.nl.nt.ims.hr/languages/EN/support/manuals/KDC-60-5060R.pdf
  3. DITTRICH
    DITTRICH
    Thanks for the speedy response. I'm really impressed. The unit came with the 2nd hand car I bought. I did try several searches on the net but sometimes you need to know just where to look.
    Les
