Kenwood KDC-237 - Deonstration Mode Problem
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Bassman, Sep 5, 2007.
  1. Bassman
    Bassman
    I bought the unit a couple of weeks ago and have been trying to turn off Demonstration Mode. I have followed the instructions in the manual and can't seem to get demo mode off. Anyone else got this unit?
  2. james_19742000
    james_19742000
    Oct 8, 2004
    666
    +18
    I have a Kenwood unit, not the one you mention, and I had the same problem, if teh same as mine, put it into stand by mode, and then go injto the menu, when demo comes up play around with the other button and it should change, again I got very frustrated with it and eventually it changed, just a case of keeping going, but it is very frustrating!!!
    James
  3. dtweek
    dtweek
    Dec 30, 2006
    67
    when in stand by push and hold menu. then with then tuner button navigate to where it says demo mode on then push and hold the tuner button for about 5-10 seconds and it will change to off. incidentally you'll need to do the same to turn the aux on to connect your ipod. far more fiddly than it should be!
  4. markbingo
    markbingo
    Nov 10, 2004
    822
    46
    Cambs
    +124
    Same unit.... same problem....google brought me to AVForums... problem fixed.
    Thanks!
    :thumbsup:
