Kenwood Dnx5240Bt + Edge Active Sub-settings
maarten1
I have bought a new head unit for my focus ST as I wanted a few more features like bluetooth and Satnav. I bought and installed the Kenwood DNX5240BT and love the gadgets on it but the sound was dissappointing. I was advised that a quick fix was to add an Edge Actice Sub and it has made quite a bit of difference.
Edge EDB12A 12 Active Subwoofer Sub Bass Box Enclosure [Edge Audio EDB12A 12 Active Bas] - £91.99 : Autocruisers
I am now confused about the setting up of the Sub. I have flicked through the headunit manual and it shows a crossover menu but I have no idea how to use it.
The subwoofer also has settings on it that are Crossover freq control, Bass boost and Gain control.
At the moment I have turned the bass all the way down on the headunit and treble and mid are just above half way up. This sounds ok but I am sure it could be better.
Any help will be great.
