Kenwood budget DD/DTS amp search
Discussion in 'AV Receivers & Amplifiers' started by DPS, Apr 21, 2002.
  1. DPS
    DPS
    I was looking for the kenwood 50-50d on qed s website, as I need a good quality cheap DD/DTS amp.Only to find that its out of stock,or has been replaced with a new model the Kenwood v40-60-s.Its around the same price, but as its new there appears to be no specs.Is this the 50-50d s relacement.
    Anyone know were I can purchase a Kenwood 50-50d from preferably silver.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    TRY Richer Sounds, Empire Direct, or Superfi. Superfi have a sony STRDE475 at £172.99 £7 cheaper than RS, get RS to price match and get it for even less. Hope this helps.:D :D :D
  3. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    I don't think the Kenwood 4060 replaces the 5050 because there is a 5060 in the new Kenwood 2002 range, Full details on the Kenwood Europe Site. According to AV Land site the 4060 and 5060 are due out now, The rest of new range are due between June and July.
    Hope this helps
    Scott C.
