L
larshoeg
Got my 5220 yesterday and tried to customize it with a personal background image. I used jpeg's only (should work according to the manual) and tried via both USB and CD-ROM. I could display all the images on both devices.
The problem: when I go to User Interface I'm supposed to have the options User Select and Change (from manual). Instead it says 'Default' and 'Change', but the Change-button is disabled/inactive. Therefore I can't use it..
Anyone had this problem or sorted it out??
Would be very happy to get a sollution on this one
Regards, larshoeg
Regards, larshoeg
