Kenwood 4060 front speaker size option?
Discussion in 'AV Receivers & Amplifiers' started by dukebox_1st, Mar 1, 2003.
  1. dukebox_1st
    dukebox_1st
    Feb 2, 2003
    26
    Edinburgh
    i've bought my kenwood 4060 a couple of weeks ago and set it up at the time and then went on holiday. wheni set it up i went through the guide but couldn't find the way of chosing the size of the front speakers. in the menus it seems to just skip it. after reading a few magazines on holiday i found that setting the fronts to large if floorstanders makes a large difference to reproduction. atm i'm disappointed in the bass of my floorstanders both in music and films and i think this might b the problem as by default the amp will select small/normal.
    has anyone got any idea where this option is hidden?
    thanks in advance
    tom
