Kensington type lock for Samsung tv attached to wall with ultra slim mount
Superfly Jon
My new tv comes with a kensington lock slot on the back so I was thinking of securing the tv. I tried a computer lock from work but it was too deep, there is only a bit over 1cm gap from the bit of the tv with the lock slot in.
Does anyone know of a kensington type lock that will fit in this narrow depth?
Jon
Member252055
Usually the kensington locks meant for laptops have a smaller fixing and thinner cable. This may be more suitable.
Hope this helps.
Regards
Graham
Trollslayer
I don't understand why they put the slot on big TVs, a good yank and the plastic breaks away.
We had this happen when someone broke in at work a coupel of years ago.
Member252055
Yes, that's true. It may be better to forget the Kensington bit and just put a loop of decent security cable around the bracket fixing on the rear of the TV and through an eye bolt in the wall.
There's no 100% solution to this. The other option is to use tamper proof screws on the locking mech on the bracket. This means the TV can't be removed easily from the bracket so then you can't get it off the wall.
Regards
Graham
Superfly Jon
The samsung slim mount is just like a picture hanging on a wall so the tv can be just lifted off the wall and so there isn't anything mountwise to secure either.
Next door was burgled recently making me slightly paranoid...
Member252055
Ah ok...
As an option then you could use one of the other two wall fixing points in the TV to attach a cable with a security/tamper-proof fixing then attach the other end to the wall.
At the end of the day, if someone's in your house and wants the TV then they'll probably get it unless it's on a standard type wall bracket with a plate and arms, in which case they'd have to yank the bracket off the wall.
I don't know if you have a house alarm but you can also get individual door sensors which can be used between the TV and wall to detect the TV being lifted off the wall, sounding an alarm. A bit like a shed door alarm. This may be a better deterent...
Regards
Graham
