Kenmark LCD stand @ John Lewis
Discussion in 'Home Cinema Buying & Building' started by fathead82, Jun 8, 2005.
  1. fathead82
    fathead82
    Does anyone here have one? I know my LCD screen will on this stand, but I'm a little worried my HTPC won't. My case is 17cm in height, 34cm wide & 46cm deep.
    Can someone pease confirm this will fit on a shelf??
  2. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,439
    Somewhere being wrong but staying strong
    +5,409
    I will check for you, should be able to post reply tonight.
  3. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Yup, She'll fit OK. Bottom Shelf is 18.5cm and top one is 19.5cm. If it's the wide one (1.1m) there's tons of room.
    Excellent quality too!
    Jimmy
  4. fathead82
    fathead82
    Jimsan which model did you get? I would prefer the smaller of the two to be honest - ones about £70 & ones about £80.
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Can't remember the model no. but it is the biggest one at over a meter wide. There are three in the range. I think the shelf widths are the same across the range.
    Jimmy
  6. domtheone
    domtheone
    Nov 23, 2004
    14,827
    Nottingham
    +3,593
  7. fathead82
    fathead82
    Yup thats them, I was after the £69.50 one, but like all stands they never tell you the shelf height! I've a fairly large Silverstone LC10M+ HTPC case which I need to get on the shelf!!
  8. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    They are astounding quality! IMO better than both Alphason and Optimum.
    Listen, Fathead, (that sounds rude, doesn't it?) it is possible, with a modicum od DIY skill, to adjust the height of the shelves to suit yourself. The are quite simply made, and a few spacers here and a bit of hacksawing there would allow you to make one shelf taller and the other smaller. The wee one you are talking about is very wee! I got mine from Comet, and I believe they still have some in stock. Take your measuring tape!
    Jimmy
  9. saint123
    saint123
    Feb 6, 2005
    57
    I got a 70cm wide corner unit for £47.99 from Index...they're having a closing
    down sale...there's 50 cm between the legs and 19cm between each shelf... :)
