Noticed the Bk sub. How do you find it? Thinking of buying that model.
The BK is absolutely brilliant. It works really nicely with the A'Diva's as well because it is so versatile and fills in the gaps (as they're little speakers). It goes loud and low when needed too, albeit it isn't the brute that my old XTZ 12.18 was
The fit and finish are absolutely top notch and down-firing is perfect for me in my lounge due to the small kids running around, poking things
Nice looking speakers Matt.
Have you tried removing the jumpers and seeing how they sound bi-amped?
I’ve checked the spec of both the speakers and amp and you do have it at your disposal to see if you can further improve things.
Consult your user manual (page 16) or, to make life a little easier, page 18 in the following pdf:
I've not got round to bi-amping them yet, although I am tempted to. They are attached to a single strand of QED XTR40 bi-wire (each) at the moment so it wouldn't be much hassle. Something for a quiet evening
I've used this amp in bi-amp mode before so I know how to do it, but thanks
. I do still keep staring at Arcam amps online though (my friend had one and it was thumping).Gah!
