KEF XQ5 speakers
Discussion in 'Home Cinema Speakers' started by Rip, Feb 27, 2005.
  1. Rip
    Rip
    Aug 30, 2004
    561
    Trowbridge
    +42
    I have a pair of B&W DM604's for left/right, would the KEF QX5's be a upgrade from the B&W's, if so, buy how much ?. My B&W's are about 4/5 years old now.
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    253
    Try and get a home demo with the rest of your kit and make your mind up after that.
    Fish
  3. Rip
    Rip
    Aug 30, 2004
    561
    Trowbridge
    +42
    The chance of me being able to get a demo at home of these speakers will be virtually nile :(
  4. superpixel
    superpixel
    I've heard the XQ5's for a brief period only, but they were an absolute joy to listen to. Finally - a speaker with transparency, air and detail that can rock 'n roll with gusto and dynamics too (and at hefty volumes too....).
    I'm quite sure you'd find them a stepup in the resolution stakes - but as you know, that alone does not maketh a loudspeaker.
    A quick demo at a dealer will be enough to tell you the difference. I'd say at that price though, a home demo should be offered to be honest, and other alternatives considered: if the Kef's dont suit, you should find a pair that do - although those B&Ws have presence and generosity aplenty, so be careful when upgrading what ain't broken...
  5. Rip
    Rip
    Aug 30, 2004
    561
    Trowbridge
    +42
    superpixel, they are indeed wise words you speak, I shall heed your advise as i go forth into the wilderness of the av dealers, & i shall say unto the dealers..........demo me some of your QX5's :thumbsup:
  6. Mell0
    Mell0
    Hiya lads & lasses
    I would like some advice on a home entertainment system to be used for both music and cinema. I have come up with the following system and would like some feed back on weather this is a good choice or not or if u have some other recommendations. From what I have read it seems have had some good reviews.
    Amp – Denon AV2105
    Speakers – KEF Q series
    Front – Q5
    Centre – Q9
    Rear – Q1
    Sub – PSW3000
