Kef THX speaker hanging
Discussion in 'Home Cinema Speakers' started by ilkand, Dec 4, 2003.
  1. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    Need some help hanging my kef thx speakers on the wall please.
    Due to buying second-hand, taking no notice of what goes where when taking the grilles off and being unable to understand the annoying manual, I have four small brackets and two larger brackets and no idea what goes where. In particular, neither type seem to fit the centre speaker which has no obvious holes anyway. Is there a super length one for this?
    Thankyou
    Andy
    P.S. anybody want to sell two white sleeves for the front left and right? (even better, swap for my black ones)
  2. upallnight
    upallnight
    Jun 11, 2003
    1,817
    63
    watford
    +107
    you will have to place the brackets yourself
    i have mine on stands but as long as you use the screws provided you will be fine
    i would suggest putting the brackets about 2-3inches from the top on all speakers
    as for the white grilles i was in the same dilema when i got mine
    you can buy them from kef ,about £15 each
    hope this helps
  3. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    Was that from KEF themselves or an authorised dealer? (I Should just email KEF , shouldn't I).
    There are a few KEF dealers near me, but not KEF THX dealers.
    Thanks for the help
    Andy
  4. upallnight
    upallnight
    Jun 11, 2003
    1,817
    63
    watford
    +107
    you can go directly through kef
    i used a local dealer, who aren't kef thx certified(which doesn't matter)and they came in about 2 days
    cheers
    leigh
